Change wheels on 3 speed walk behind 2000 LB 6.5
lewb
The wheels are ok, I just need something that has more grip, I have a severe slope to get up, if grass is somewhat wet the mower does a lot of slipping. I have to cut lawn at an angle probably 35 to 40 degree slope. Thanks
Use Lawn Boy part number 115-1454, best price at Do-Cuts Power Equipment Warehouse 1-866-276-6086 in Ohio @ $26.87 ea. + shipping. These are a direct replacement wheel kit, including a mtg. bolt and spacer. Replaceable tread steel hub with 2 sealed ball bearings. This is a commercial duty easy to install and very easy rolling long lasting wheel. The tread has more aggressive tread pattern than the original wheels for better traction. They are painted orange.
Thank you,
Got the wheels yesterday installed this AM did a quick test on the hill that is very wet, walked right only need on hand. The stock wheels do not turn on a bearing just a bushing, the commercial have bearing pressed in to hub.
