Change deck sizes
Gibsontb4
I have a Broadmoor with a 38” deck that is having engine issues. Just picked up a slightly newer Broadmoor with a 44” deck. The deck on the 44” has the electric adjustment and everything on it needs to be gone through, rebuilt. Can I put the 38” deck on the mower with the 44” deck and use it. The 38” deck mower has a 16hp Vanguard engine and the other has a 22hp B&S Professional engine. Thanks in advance for responding.
Tiger Small Engine
Swapping decks is usually not that easy. You won’t know until you try.
