G ghost1 Well-Known Member Joined Mar 6, 2011 Messages 195 May 18, 2019 #1 I'm working on a chainsaw UT 10883, and am in need of the following part. Homelite 04933A Washer, Cupped It shows as obsolete and wondering if anyone might know a substitute?
primerbulb120 Lawn Addict Joined Nov 3, 2014 Messages 1,315 May 18, 2019 #2 Many of the newer Homelites use a similar washer in the clutch, part 631060001. Worth a try.
G ghost1 Well-Known Member Joined Mar 6, 2011 Messages 195 May 19, 2019 #3 Thanks Primer Bulb. I'll give that a try
primerbulb120 Lawn Addict Joined Nov 3, 2014 Messages 1,315 May 19, 2019 #4 It probably will work. The shaft sizes should be the same...
