Thank you for the info but I am trying to find a used one to save a little. I have found a lot of heads that looks the same but different part numbers. I am sure that any modifications that kohler does changes the part number. Thank you for your reply. What is wrong with mine is the mount boss for rocker got loose and beat a slight depression on the boss or shoulder.
