2cyclegreenmachines
- Aug 18, 2024
- 12
Model 8237 Ser 9424117. I am trying to save this one from the scrapyard. I pulled the engine and disassembled. Replaced bearings and seals top and bottom of crank and the drive shaft bearing and seal. Light hone of cylinder just enough to clean it up and put the crosshatch back in it. New needle bearings in connecting rod and new std size rings. Piston had no scoring, so it was reused after a good cleaning to remove carbon and varnish. So far so good. Yay! Crank spins freely and I have suction at the carb and compression at the plug. Rebuilt carburetor and re-installed powerhead on the deck. Now I cannot find the CD pack ignition coil I removed and must acquire a replacement. The coil I removed was off white plastic with just the mag pick up metal sticking out and one terminal that went to the Off / On switch. I am at a loss as to the correct part number for the replacement coil. Can anyone assist in providing me with the correct coil number?
David in Dayton, TX
David in Dayton, TX
