Thanks for the video Boudreaux. The linkage running from the carb to the governor on my engine has a different configuration than that on the engine in the video. Amazing that Briggs builds so many different engine models within the same class/hp. I am attaching a picture of mine just for show. When I originally took the carb off to clean it the linkage was in the hole on top without the plastic grommet. After several times removing the carb to try to determine why gas would flood at odd times and why the engine would race,run as if it had no power and ultimately die,I moved the linkage to the hole with the grommet. Now maybe it is in the wrong hole now and the big problem was the float somehow sticking to the bowl just enough to cause the fuel supply to fluctuate not allowing enough supply while running and then flooding when off. I guess I would not know unless I were to put the linkage back in the hole without the plastic grommet and see how the engine speed runs. If the engine continues to operate normally next time I mow I am inclined to leave things as they are.
Best,
Billy
