Carburetor, Fuel and Solenoid question?
The one large enough for the Kawasaki FD731 is expensive if you use the Honda VT600CD PN16970-MZ8-U53. It is on 583CC engine where the FD731 is 675CC engine.
But there is an after market version with an shut valve that you just toss on eBay.
https://www.ebay.com/itm/403630302185
or just the valve
As for installing you need add a vacuum port in one of the rocker covers and make your own mounting bracket.
Hardluck
Thank you.
For the vacuum can I splice into the vac line for the fuel pump it will it not have enough vacuum?
Should be enough, just haven't had a time or chance to try this on my own mower. I didn't get to cut my own lawn until this week, that was for two months. Now I got a hay field.
