Bleach
- May 27, 2017
- 138
I've been looking for a new carburetor for my BS powered generator. Does anyone sell NOS carbs? All the ones I seem to find are chinese knock offs of dubious quality. The model number of the original carb is 690115 which superseded 690111. I wonder if any other BS carbs will work. A couple OEM's I've seen are around $200!
Rebuilding my original carb is not really an option. It got gummed and corroded from sitting with old gas in the bowl years ago. I cleaned it up as best I could but it can be a real bear to start the engine sometimes. I got it to run after spraying a little gas down the spark hole which seems to be the only way it will start now.
