carburator rebuild help needed.
slyme
Im working on a b/s 17.5 engine and I cant get the carb.to work.I've taken it apart and cleaned it 3-4 times and no luck.
Can some one give me some pointers please.
I have; soaked in degreaser,shot carb.cleaner and ran wire through ports, compressed air through ports.Cleaned fuel tank, new fuel lines. Thank you.
Lawnboy18
Is everything installed back together correctly? I recommend checking out a diagram.
slyme
Thank you for the reply!.And yes,i do have another 17.5 parts engine, with carb.installd factory , that I went by.
Lawnboy18
Do you have fuel spark and compression?
mechanic mark
slyme
Yes.I do have good compression (120psi)fuel,fuel tank,and lines are good and clean.Good spark aswell.It dose turn on when I drop fuel into carb.But wont stay on.
engine info; Mo;267707 Type:0225-01.Code:9511174B.
Thank you.
Lawnboy18
It may just need an adjustment with the needles.
Lawnboy18
There are screws on the carb that you can play with. You will have to check a manual.
Make sure gas is coming to the carb. Also, maybe your float is not working correctly in the carb.
So, before adjusting the carb, check that gas is going to the carb and that the bowl is placed correctly.
