carb
tgbu7500
carb numbers 593198 602824 6510,motor model 40n877 type 0015g1 code 160929yg.cant find a one barrell carb.does anyone know the part number i should search for?
According to the engine numbers you posted the carb for your engine is 595216, which is superseded to a 597126, which I have found is available on the web. Question is always, are you getting what you want. Need to order from a reputable dealer.
