I need to rebuild a carb on a 18 1/2 hp briggs engine. Where could I locate any help on this?
thanks. gas is coming out of the front at the fuel pump area.
You could just go for a fuel pump kit, but I would go for the carb kit, go by the pic's give the carb a good clean (jet(s) ) if you have any problem's just pop back here.
The brass seat take certain way to remove on those. I use a tap to remove it. Others on here probably do it differently. Briggs actually lists the part numbers to make your own seat remover.
