Carb problem
Tedws
I have a 143.406022 Tecumseh engine with carb #632525 . The #s on the carb 143J6P. I have cleaned this carb 4 different times and put a kit in it,however the choke has to be about 3/16 inch open for it to run plus it does a lot of popin and I have added SEA FOAM in the gas.
BlazNT
Have you checked the value clearances.
Fish
Well good, you have now just to find someone to help you to rebuild the carb correctly, I guess.
Fish
dang...I guess you really need some help.
