I have a Kawasaki 24 Hp twin (FR730V) and it uses a Walbro LSF carb. The engine surges badly at all speeds, but only under light to no load. Does it a bit when driving on flat ground and not at all when mowing.
I've cleaned it many times, but no luck. I've removed the welch plug for the pilot needle and it makes no difference where I put it, from all the way in to almost falling out.
Governor is correctly adjusted.
Any ideas on how to clean the pilot system or fix this if it's another problem?
