- Sep 24, 2017
- Threads
- 271
- 6,684
That's what I suspected.Those are two different needles, used on two different carbs. That means one of two things are going on. 1. Someone has switched carbs on this engine. 2. Your model for this engine is wrong due to poor eyesight or someone has switched shrouds. Briggs has 3 different needles with viton tips. Need to do some detective work.
Now I have seen the Aftermarket Chinese carbs use a Viton tipped needle, on replacement carbs. So it's the correct carb but the Chinese just use a different needle
Set up
