rocket9244
- Sep 20, 2016
- 17
does anyone know the carb adjustments for the carb on a BV 165 blower/vac? it was running a little rough so I adjusted the screws all the way in and then 2 turns out, and now it wont start. what are the proper " turns" so it will start, so I can finish adjusting it? it seemed as though I had to turn them in a lot to " seat" them before I tried to turn them back out. it has " Mix" and " Idle " screws, not "H" and "L".. Thanx
