Carb Adjustments: BV 165 blower/vac : help?
rocket9244
does anyone know the carb adjustments for the carb on a BV 165 blower/vac? it was running a little rough so I adjusted the screws all the way in and then 2 turns out, and now it wont start. what are the proper " turns" so it will start, so I can finish adjusting it? it seemed as though I had to turn them in a lot to " seat" them before I tried to turn them back out. it has " Mix" and " Idle " screws, not "H" and "L".. Thanx14207856_10157441063775142_8542511025284449175_o.jpg
does anyone know the carb adjustments for the carb on a BV 165 blower/vac? it was running a little rough so I adjusted the screws all the way in and then 2 turns out, and now it wont start. what are the proper " turns" so it will start, so I can finish adjusting it? it seemed as though I had to turn them in a lot to " seat" them before I tried to turn them back out. it has " Mix" and " Idle " screws, not "H" and "L".. ThanxView attachment 29968
The "Mix" screw adjusts both the idle and high speed mixtures. Turn the "idle" screw in all the way and unscrew the "mix" screw 2-3 turns. Then try to start it. If it still won't start, try some starting fluid.
weird. after letting it set for a week, it started right up. I adjusted the idle and mix screws to where it runs good. the mix screw is about 1.1/2 turns out as where the idle is at least 10 screws out. so, could it have been flooded and or a bad line or something possibly?
Might wanna check the spark 'color' after some use.
When doing carb adjustments, I find it best to add new spark plugs, then after it is run for a while, pull plug(s) & look for the beginnings of a light tan brownish color.
Black would be TOO Rich. Which would waste gas & more importantly wash the oil off the cylinder wall(s). Causing premature wear.
