Ric
- May 7, 2010
- 139
- 5,765
The 125 Frame is 1.5x2" 11 ga. The ZM is 1.5x3" 10ga. so it's larger and heavier. The spindles Are a 6" 4 bolt the ZM spindles are an 8" 6 bolt spindle larger and heavier and both are cast Alum. Everything on the ZM is or has sealed bearings, nothing needs to be greased except the idler pulley And the spindles on the 125 need greasing along with the casters and wheels and it has a 5 gallon tank and the ZM has an 8 gallon. It also has adjustable dampers for your lap bars. The 150 your talking about is more comparable to probably the ZM 3000 which is more money, not the 2000.
