garage_hacker Member Apr 24, 2023 #11 slomo said: The OEM Briggs carb to block gasket is like 1/8" thick or more. If you buy a Chinese Amazon or Ebay carb, they give you a much thinner gasket. Click to expand... Ah, thanks for that wisdom - yes, it came in the same box with the chi-con carb.
S slomo Lawn Pro Apr 24, 2023 #12 Again the Briggs gasket is like twice as thick and the Chinese one. Obviously use the Briggs part.
