suzie queue
- May 1, 2013
- 1
- 3
I have a Wizard riding mower and I never have any trouble starting it. Last fall, I was using it quite a bit to haul a weelbarrow sized cart full of firewood to stack on my front porch. After I was done. I turned it off to use again the next day. It wouldn't start. It was low on gasoline so I filled it up. It still wouldn't start. So, since I had another riding mower, I just parked it for the winter to deal with it in the spring.
It is now spring and I have completely drained the gasoline and put in fresh. I have put in a new spark plug, new gas line, new in-line filter, cleaned the air filter, and changed the oil. It still won't start. I have had to charge the battery twice because of running it completely down trying to start it. I have sprayed starter fluid in the carborator and it fires so I know the plug is good and I always mark new plugs with the name of the equipment it goes in when buying them, so I know I have the correct plug.
Where do I go from here before calling a repairman.
