can't start Kohler engine after it get's hot
We have two tractors at a cemetery were I volunteer to help out. Both tractors have Kohler Command 20 two cylinders engines. The one after you run it and it get's hot and shut it down you can't get it started again till it cools off. I have not been there when it happened so I don't know if there is any fire or what is going on. It seem unlikely that both coils would brake down at the same time. I had a coil go bad on one of them before but it run on one cylinder. any help anyone can give me will be appreciated
