- May 6, 2010
- 44
- 10,911
Re: Can't Identify Sample/Test engine on my mower. Update: Prototype Aegis 23HP
The 12v may go through the key switch, but the B terminal on the regulator can also be wired to the + terminal on the battery or the terminal on the B+ side of the solenoid.
In the last few years Kohler has recommend that the wire connected to the B terminal on the regulator be wired battery hot.
On a 6 post, 3 position ignition switch, is there supposed to be a post that is key hot? I'm getting the nominal 41 volts out of the 2 AC connectors on the reg/rec but where does the 12v DC come from on the middle connector? Where does it connect to? (the B+ middle connector on the reg/rec) I checked it with the engine running and I get NOTHING.
