Hi,
My husband and I removed the deck of our i1046 Cun cadet to sharpen the blades. Now we can't get the belt back on. According to the manual, you should first attach the front deck hanger rod onto the front deck hanger bracket. then the deck rear hanger bracket goes onto the deck lift arms. Then you are supposed to face the front of the mower, reach down and slide the belt onto the right side of the PTO pulley, sliding the belt to the left and rotating the pulley so the belt goes into the grooves in the pulley. Two problems, the PTO pulley doesn't rotate, and the belt tension is so great there is no way to force in onto the pulley. Anyone have any suggestions of something we can do to release the tension?
