Can't Find Tire Leak
kbowley
Over the years I have had this problem too.. I can relate... most of the time, I found the problem to be a VERY VERY small leak around the bead... I use a little kids swimming pool... the plastic one you know.. that people give away and filled that and submerge the whole wheel/tire... What I always wanted to try was to set up a camera and use it with the tire submerged and a couple hours later, replay the recording on Fast Forward to see where the bubbles were coming from.... but never got to it... so I went to Plan B especially on rims I was pretty sure were leaking around the bead... and I break the bead on both sides, clean up the beads with steel wool or whatever method you choose and coat the metal and rubber with rubber cement and let it set for a good half hour and then inflated the tire and hope... if that was it, problem solved... you could also replace the valve while the beads are broken and then do a stupid move like I have done and dropped the old valve inside the tire... "eye roll here"..... I don't know how many times I have found a "brad" in the tire as well... magnifying glass? and PS... I had a Sears mower that had a low tire ALL THE TIME.. I never did find the reason for that.... AND finally.. one more thought... usually to find a leak you use "soapy water" but with an extreme slow leak, that makes the problem worse.. use clear water so you can see minute bubbles.....
You better pray you never have to remove that tire after using cement...bad idea IMHO.
Gord Baker
Put 20 PSI in the tire and spray with Windshield Washer Fluid or soapy water. Sit it in the Laundry Tub for longer soaks.
kbowley
Anyone use Slime yet?
PLEASE do not put slime in the tire...it won't last for any length of time and is a royal mess to clean the inside of the tire and rim when you decide to fix it correctly by putting a tube in it.
Gord Baker
So much wasted time here on a slow leak. Do the Hanes Test. Take your wifes or Girlfriends nylons and wipe it around the inside of the tire.
If it does not catch on anything you're good. If it does remove the foreign object. Then buy and install a tube. Get help if you have not done this before. Next time take it to a Shop.
GrumpyCat
You know of a glue that sticks to steel rims?
There are specific bead sealer products for sale. "Glue" by any other name. Can sometimes band-aid cracking or torn tire beads.
kbowley
Good lord...this is getting nuts. Simply put a tube in the tire, and problem solved. Most small engine shops will install a tube for 15 dollars, not including the cost of the tube itself. Problem solved.
Gord Baker
Buy a new F'ing tire!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
GrumpyCat
Buy a new mower!
Get Tweels!
No problem is too trivial to solve with money!
