Ida-Boy
I want to try and fix an oil leak on my HR215SXA but can't seem to find it. It seems to be coming from under the flywheel... It taks several minutes before it starts to leak but with the flywheel spinning around it blows the oil all around. I did replace the seal on the shaft and that breather seal (cork gasket)... I believe I have the shaft seal in correctly. Any Ideas? :confused2:
