Can't find a carb.
BADGolfer1978
I need a Carburetor(number) for a Troy-Bilt Pressure washer Model 020209 Serial1009988084 B&S Intek 7.25.
I think the carb number is 798653 but to be sure
Get the engine model number off of the Valve cover, it will be stamped onto the side of it. it should start with 11______ or 12____
type that model number and type number into any online mower parts store and that should bring you to the parts diagrams where you can select the proper breakdown and get your part.
