Alex Ethridge
- May 25, 2019
- Threads
- 18
- 77
They are different or the manufacturers would not recommend one over the other.Again....10W-30 IS 30 weight.
I'm looking for Castrol 30W oil and cannot find it anywhere, on-line or locally. I've checked AutoZone, Advance, O'Reilly, Walmart, Lowe's and Home Depot. So I decided to try for other brands, brands I recognize, not this cheap unknown stuff. The only straight 30W I can find is Super Tech but I have seen the independent wear test run on it and is ABSOLUTELY NOT as good as the nationally-recognized name brands.
I have been using this for over 4 years off & on. Now it is all I use in my Equipment that requires 30w oil. Haven't had any ring, valve or other issues. I do change oil regularly.I'm looking for Castrol 30W oil and cannot find it anywhere, on-line or locally. I've checked AutoZone, Advance, O'Reilly, Walmart, Lowe's and Home Depot. So I decided to try for other brands, brands I recognize, not this cheap unknown stuff. The only straight 30W I can find is Super Tech but I have seen the independent wear test run on it and is ABSOLUTELY NOT as good as the nationally-recognized name brands.
I see Castrol HD 30 Monograde Conventional Motor Oil at Walmart online. Its expensive though at $19 QT. Ebay has better prices for it though and free shipping.I'm looking for Castrol 30W oil and cannot find it anywhere, on-line or locally. I've checked AutoZone, Advance, O'Reilly, Walmart, Lowe's and Home Depot. So I decided to try for other brands, brands I recognize, not this cheap unknown stuff. The only straight 30W I can find is Super Tech but I have seen the independent wear test run on it and is ABSOLUTELY NOT as good as the nationally-recognized name brands.
There's not one thing wrong with using Super Tech in a lawnmower. It's not a Formula 1 racer turning 10,000 rpms. It has the spec.I'm looking for Castrol 30W oil and cannot find it anywhere, on-line or locally. I've checked AutoZone, Advance, O'Reilly, Walmart, Lowe's and Home Depot. So I decided to try for other brands, brands I recognize, not this cheap unknown stuff. The only straight 30W I can find is Super Tech but I have seen the independent wear test run on it and is ABSOLUTELY NOT as good as the nationally-recognized name brands.
Plus, nothing used or leaked oil more than a 1911 Harley! So, quit wasting money on stolen oil resold on eBay for $40/gal.The SuperTech may not be as good as some national brands. Well, you can do your changes on shorter intervals if you feel it does not provide adequate longevity. Checking the links, $10 for a quart of Pennzoil is a bit much for me. The Walmart links are less pricey at least right now. I cannot understand $40 for a gallon of 30W, no matter the brand.
I'd use the SuperTech as it meets the standards specified. These machines are not in the same class as a 1911 Harley so should not need more than the manufacturer required. To each their own as likely no one will agree with my comment. I use SuperTech 30 non-detergent in my B&S branded china compressor. Lots better than the muck that was in there when I got it.
You have my permission to be of that opinion.There's not one thing wrong with using Super Tech in a lawnmower. It's not a Formula 1 racer turning 10,000 rpms. It has the spec.
