Repairs Cant Adjust Idle On Koher Engine
davbell22602
Sears GT3000 50in deck
917.275031
Kohler CV675 23hp vtwin
Engine speed only runs on on wide open. I move the throttle down and engine speed doesnt slow down. Everything from what I could see moves freely.
Fish
Did this happen all of a sudden? Have you tried checking the gov. adjustment?
davbell22602
May have been like for sometime. I picked the mower for $50. Replaced one coil and engine harness. Its up and running again. I started messing with the governor linkage. Thought I found the cause. Started engine up. From open wide throttle I got slow down. Then I couldnt get it go in open throttle again til moved the cable lever up and down couple times. Then all sudden it jumps back to wide open throttle. Then I couldnt get to slow down to idle when using the cable. Cable moves freely.
