Can you wash a Briggs and Stratton riding mower engine?
jay1957
  • / Can you wash a Briggs and Stratton riding mower engine?
I am getting ready to clean my John Deere E170 riding Lawn mower, and I was wondering if it was safe to rinse off the engine?
Try a leaf blower or compressed shop air first. Pull the engine shroud and clean the cooling fins, all around the block.
I applaud the cleaning effort. Turtle Wax the deck and apply used motor oil to the under side of the deck. Tires properly aired up. Valves ran.
jay1957
Thanks for the information, I only have around 14 hours on it. I had to have the original engine replaced after only 10 hours on it. It came with a 25HP, and the John Deere dealer put a 24HP on it. I don't know what happened to the first engine other than it sat for over a year during COVID and only ran for five minutes when I started it, and never ran again. I did get rid of the quick oil change filter with this new engine.
Auto Doc's
Wash it carefully and then blow as much dry as possible with a leaf blower or a shop air hose and nozzle if you have one. Avoid getting the air cleaner inlet wet,
DK35vince
Just avoid the air filter.
My tractor and zero turn engines get pressure washed.
