can someone help me
ronnie bowman
i have a cub cadet rzt50 mower,and the motor trown a rod,so i put a briggs motor on,and can not get it charged,i need to know how to fix this,i have a red and whte coming from under the fly wheel,i hooked up a batt wire to the red,and i dont know where to hook up the white wire,please someone help me with this
aandpdan
What model engine?
It sounds like you have a "tri-circuit" alternator. The red wire is for the battery charge. The white wire is for lighting.
ronnie bowman
What model engine?
hello,thanks for reply,so you are saying that if a hook the red wire to batt,and i need to hook the the white wire to the what !
aandpdan
The white wire would be if you had lights. If you don't you can just leave it disconnected.
Are the wires before, or after the voltage regulator? I am thinking there should be a yellow wire there somewhere.
chance123
You "DON"T connect the red wire to the battery! Your alternator produces AC voltage and your battery is DC voltage. You must have a regulator or a simple diode which allows the current to flow only ONE direction (so the current does not go back from your battery and into your alternator stator) therefore producing synthetic DC voltage. (AC voltage + and - goes both directions)
