Can I paint the flywheel without it affecting the ignition magnet?
I've got an engine with rust build up on flywheel, so much I can hear it rubbing on the coil arm gaps. The engine has been sitting awhile with no use. I could just sand it off and put oil on it, but figured if it won't hurt the ignition why not just paint it with rust paint(?).
