Berniebac
- Apr 8, 2012
- 25
- 180
I have my 14.5 HP Briggs out of my tractor. I have been undertaking some repairs to the engine and am nearing completion on them. I am just about ready to reassemble the carb, heat shield, cover, etc and thought it would be nice to test the engine before I reinstall it in the tractor. The tractor is currently a two hour drive from where I am repairing the engine.
I was wondering if I could hook some jumper cables from a battery to the engine block for a ground and then touch the positive cable to the starter to start the engine to see if it runs. I could hook up a temporary gas supply with a small plastic tank I have. It doesn't have the exhaust hooked up so it will be loud.
Is it safe to do this without harming the engine? If I can run it on a bench, how would I shut it down?
