CAn I attach a Wood Chipper to a Poulan Pro 22HP
Freedom
Hello,
I have bought a Poulan Pro 22HP, It workd very good!
I would like to analyze if it is possible to move the tractor to a place in my property, change the belt and connect a chipper with a new belt.
What do you think , is possible, ? is worthwhile?
Thanks!
Ricardo
Nothing wrong with that used to be the norm back in the day when machines were expenssive and lobour was cheap.
The only problem comes with the drive belt slipping.
If it is a vari drive or geared mower it is fine cause those belts don't slip when the tractor is standing still so you can leave it there, engine running and brake on.
On hydro models you will have to chock the drive wheels so it can not move and leave the brake off.
If you have a hydro drive I would remove the belt to the hydros because as long as the belt is moving you are using the hydro drive and waring it out.
