Deltatango
- Aug 24, 2016
- 2
I am in the UK and have an old Mountfield mower of pre- 1997 and two stroke, its fitted with a Tecumseh engine and carb which has taken to letting petrol out of its air filter so suspect float etc.
Problem is this mower is a bit of an odd one which seems not to exist in service manual land for Mountfield, I think it was one wedged in between listed models.
So I am trying to understand Tecumseh numbers and where so hidden, On a plate fixed by one nut by the carb' I read 12001A and AV85S as near as I can tell, on the carb' body' I think I read FHC201 with a possible 8 or S afterwards. Also its air intake is a simple oval sponge design.
Can you help me identify from these or suggest other places to look.
Many thanks from David:confused2:
