Can anybody tell me if or what other cams will interchange with 21 hp briggs vanguard motor
B binckley Forum Newbie Joined Jul 12, 2016 Threads 2 Messages 7 Jul 13, 2016 / cam swap #1 Can anybody tell me if or what other cams will interchange with 21 hp briggs vanguard motor
M mechanic mark Lawn Pro Joined Jul 15, 2013 Threads 176 Messages 7,494 Jul 13, 2016 / cam swap #2 Post model xxxxxx, type xxxx, trim xx & code number from engine data plate. No other camshafts will work properly unless they are from a Vanguard engine with part # 690927. https://www.briggsandstratton.com/n...nginemanuals.html?searchrequested=385777-0349 pages 2 & 12 in parts manual, part # 690927 https://www.google.com/search?sourc...927&oq=b&s 690927&aqs=chrome..69i57.21271j0j8 http://rich.homeunix.com/gravely/pro16/272144 Vanguard Twin Cylinder OHV BRIGGS & STRATTON.pdf engine repair manual Last edited: Jul 13, 2016
B binckley Forum Newbie Joined Jul 12, 2016 Threads 2 Messages 7 Jul 13, 2016 / cam swap #3 21 hp briggs vanguard v-twin 385777 0349-e1 04022511
D darrinster Well-Known Member Joined Sep 9, 2015 Threads 24 Messages 111 Jul 14, 2016 / cam swap #4 If you go here it shows all the models with the same camshaft http://www.jackssmallengines.com/jacks-parts-lookup/part/briggs-stratton/690927
