Cab Cadet 30" Electric Rising Mower with Bagging system
hoaguy
Does anyone have any way to increase the flow of grass clippings into the bagger? The tube gets clogged easily. Has anyone added a second blade like some of the newer push mowers have? I was thinking this might cut the grass into smaller pieces to make bagging easer.
Many things come to mind when I see this problem. Is the engine running at top speed? Should be approximately 3400 RPMs. Are you cutting at a correct height? Should be removing no more than 1/3 of the grass height, on dry grass. Is the blade turning at top speed? Worn or loose belt will slip, allowing the blade to turn slower. Are you using a blade for bagging? High lift blades are the best. Finally, I’ve found that the 30” TroyBilt mowers are on the low end of good bagging systems.
