Grats!
The deck probably isn't adjusted properly if the tires were still at shipping pressure, so don't freak out if the cut quality isn't up to par. I really hate that dealers do that! You'll likely have to adjust the pitch and level yourself.
The whole deck is offset to the left to increase overhang and trimming ability on that side. I suspect that has something to do with the front caster placements.
I keep the hydro fluid a little high in my machine as it's difficult to see if it's at the full line which is very low in the reservoir and hard to see. With it a bit higher I can check at a glance.
Thank you!
How do I adjust the deck? I do see that it is pitched up as in the front of the deck is slightly higher than the rear. Side to side appears to be pretty level.
I did also try to check the hydro fluid levels and I cannot get a good enough angle to see where they are at.
