There are many reasons why a Honda HRX is the right choice. To start off, it might be more expensive than the Toro, but I think it will last longer and is an all-around better mower. To start off, the GCV190 engine is great. Secondly, the NeXite deck on the HRX is very durable, won't rust, and repels grass! With the grass I mow, I hardly ever have to clean the mower deck! Next, the controls are great. You can get the BBC on the HRX217HYA and HZA, so you can stop the blades and keep the engine running. Lastly, it has the Clip Director, so you can switch from bagging to mulching or anywhere in between with no mulch plug! The list goes on and on, but those are some of the main points. Ask if you have any questions!
