BS 675 won't start after hitting somthing, flywheel key is fine.
hsnopi
  • / BS 675 won't start after hitting somthing, flywheel key is fine.
so i have discovered the vane autochoke is also referred to as a pneumatic governor. i still have YET to see how those two parts are connected. or rather, how they should be connected.
reddragon
ok....you really needn't put fuel stabilizer in a mower unless you plan to park it for winter.....how much did you use?
hsnopi
i used what came int he kit. so that's good to know for next time.However, I figured out, through BRILLIANT deduction, why it wouldn't start. After the tune-up I forgot to reattach the spark plug wire. :confused2:
So, it is running, it just seems to be running slow now. I think that is a matter of the carb tuneup. it still seems to vibrate though.that might still be the timing.
jackdaws
where i cann buy a blade adapter for a BS 675 engine ? thanks
