Brute 675 wont start wont run
Donald Boykin
Fuel flows pass the fuel filter and
it runs if i pout or dpray gas in the
carb. Pls help its almost 2 y/o.
Take the bolt out of the carb bowl, and clean the jet in the bolt. Most likely plugged. there is a cross hole, and a hole from the top .
either clamp off the fuel line or drain the tank prior to removing the bolt, so you don't waste all your fuel.
