Would a broken timing belt be the reason for no compression? Thanks.
B beebo172 Member Joined Mar 3, 2019 Threads 6 Messages 13 Mar 3, 2019 / broken timing belt #1 Would a broken timing belt be the reason for no compression? Thanks.
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Threads 65 Messages 24,995 Mar 3, 2019 / broken timing belt #2 Yes and cranking the engine with a valve open can bend the valve so it can not close properly. Pull the head or do a leak down test
