Broken Hydro mounting bracket repair kit
hlw49
Does anyone know of a mounting bracket kit for the hydro where it bolts to the frame. Husqvarna YTH 24V54
YTH 24V54 960430188 00 I had to search to find the model no that fit the mower. I found it under model no 960430259 00. To find the model number that showed the anti-torsion brackets.
532437498 Vertical Draw-bar Kit.
I have to open a box to see what hardware is in the kit in the morning when I go to the shop. Images online don't seem right but it been a few years since I last use a kit. Maybe they changed the amount of screws in the kits.
Sorry for taking awhile I was dog hunting with a 12ga.
Following what in the kits here except the self tapping screws are silver not yellow.
This is where the axle housings bolt to the frame. That says it is the vertical draw bar kit. I have seen that one but don't think it will work.
That is exactly what the kit is for. You remove the current mounts ie cut them off. Of course the transaxle has to be removed first. And I have installed several of them on the Tex frame. Don't know about the other frame style. I keep both the vertical and slope repair kits in stock.
Vertical draw bar ( | ) just is the type rear frame part as is sloped draw bar ( / ). The slope one requires a different kit.
See how the draw bar is designed and it welded to the two side rails. BTW the transaxle axle mounts are part of the draw bar.
Now I would use all four holes instead three but that is just me. And there is a reason why four mounting holes as the plates were made to fit both LH and RH sides for alignment purposes. You will need a very sharp drill bit for doing the holes.
