i have a 2010 simplicity broadmoor 46" deck, last year upper idler arm broke, this year 3 pto belts broke, removed deck and disassembled idler assembly's from deck. after careful inspection i found bolt that holds idler assembly's together was warped. i also found too much of a gap when passing bolt through both bushings. the factory bolt is a grade 5, 3/8" diameter one and a half inches long. my son and i drilled bushings,washers, deck and brace with 7/16 drill bit. purchased new grade 8 bolt 7/16" diameter and 2 and 1/2" long and a new self locking nut to fit. the shoulder on the new grade 8 bolt is 1 and 1/2" before threads start. installed new bolt and 1 drilled washer, greased shoulder and bushings liberally, completed assembly. i have mowed 3 to 4 acres each week for three weeks and no broken belts. i have contacted simplicity addressing this problem and received a positive response. hope this helps you out.
