Broadmoor 2691674
chetstar01
The mower deck on the lawn tractor is raised and lowered electrically as is adjusting the cutting height. I can lower the deck but can't adjust the cutting height. I've already checked and with the mower running there is 14 volts at the motor that adjusts the cutting height. My dealer can't get to it right away and I was wondering if there was a way to manually adjust the cutting height on these tractors? Thanks in advance.
mechanic mark
See pages 23 & 24 in my Broadmoor Operators Manual above & see if it helps.
