So, a little back story, I bought the mower from some guy in the woods in the middle of no where, he stated the ignition was broken but could pull start it. I heard the engine run, and saw the condition it was in and bought it for 75$, When I got it home it refused to start, not sure what wizardry he pulled to get it started when I saw it. I took the carb apart, noted that the fuel pump was bypassed from before I got it, and have let it remain so, I was cleaning everything and noted the linkage to the throlle was loose connecting it to the throttle plate, Ive since adjusted it twice but it seems to make no difference when I move the actual throttle. I'm not 100% what is going on. It's particually bad while at idle, it surges and I'm sure the engine is going to eventually grenade if not fixed. I can post some pictures later if needed, I've also noted gas in the spark plug hole which I'm assuming is the float needle becoming stuck, going to pull the carb again today and see what I find
