purisahil41
Hi folks,
I bought a yard machine lawnmower (BriggsAndStratton 675 exi - https://www.briggsandstratton.com/n...nes/push-mower-engines/exi-engine-series.html) last Fall (9 months old). I did not use the fuel completely last year and left some of it in the gas tank.
This year the lawnmower failed to start up, I followed steps as per online video to clean the carberutor and assembled it again yesterday
The lawnmower started normally after assembling but it started dripping gasoline, I realized (an hour later) that I left the "float valve needle" (https://shop.briggsandstratton.com/products/briggs-and-stratton-696136-float-needle-valve) out and did not connect it while reassembling.
I re-assembled the carberutor and set the float valve needle as required and started this morning and I don't see any gas leakage anymore and the lawn mower starts up in the first crank.
However, it is giving a lot of black smoke from the exhaust (I only ran it for 5 mins) and also a lot of vibration. I'm try to think if I should take it to a repair center or it might be extra gasonline that made it's way into the engine when I assembled incorrectly yesterday without the float valve needle.
Thoughts?
Thoughts?
