Briggs won't start
oldsman143
Craftsman MTS5500 with Briggs Intek VTwin 24HP. Engine will only start when choked then dies. Any suggestions.
EngineMan
This one is the same has (Nikki carb question)
DaveTN
Why not just clean the carburetor with spray cleaner first, then see if it helps. Then do a kit/rebuild after that. Could be some dirt in the inlet screen going into the carburetor clogging it up. A good cleaning wouldn't hurt.
