Otis3d
- Apr 14, 2018
- 7
Hi, I have a Briggs 5.5 that was given to me on a Tiller. It was locked up. I opened the case an the broken dipper fell out. I put the case back and now it turns over but won’t start. I sprayed starting fluid in and it will pop but that’s it. I took carb off and sprayed with carb cleaner. If it would fire I would get a new dipper. Is this worth pursuing or should I just buy a predator engine?
