Briggs vertical shaft 12 model
Scrubcadet10
Staff member
Community Leader
Location
Conroe
Model: 12H802-1937-E1
Code: 97071759
Doing some carb work on it,( just cleaned out the main jet) put it back on and hooked up gas, gas started pouring from the little air hole just below the air cleaner mounting screw holes. so i replaced the needle and seat, float is sitting level, put it back together does the exact same thing, gas coming out of that tiny hole again, has me stumped!! *new bowl gasket also.
