Briggs v-twin wont stay running
Freddie21
Don't jump in and start replacing parts until problem is isloated. As the Guys have suggested, get good flow from the tank at the pump 1st. Inside the tank is where many problems lie. Fuel line from it to the pump, next. Wait on replacing filter till you get good flow. Now the pump. Are all lines in good shape and not leaking, even, air? If good, check pump output. Should give a good stream when cranking. Last, the carb. Remove bowl, if easily done, or carb to clean bowl, needle, seat and jets. You could start here, but if the flow to the carb is not right, then you'll be back at step #1. Reassemble with new gaskets, in-line shut off and filter.
Etbrown44
Once you verify fuel flow, if it still not right, I would invest in a $15 amazon carb. I know some guys here don't like them, but I've not had a single one fail in the past 15 years. No doubt you might sometimes get a bad one. Still worth a try.
Freddie21
50\50% for the cheap carbs for me. At least, a cheap trouble shooting tool. I also will use them for the internal parts to rebuild OEM ones.
Just cuz the fuel lines look good, doesn't mean they are. They can close up internally just like your arteries.
thigg001
Only on almost full choke, no power. New fuel filter and air filter. Pulled fuel line and cranked, it trickled out. What is norman flow?
Briggs v-twin known for dropping push rods, not an expensive fix, but a pain.
outdoorpowermike
Test fuel pump with vac gauge/fuel pressure gauge, remove inlet fuel line and outlet fuel line from fuel pump, should have 1-11/2 psi coming out of pump and about the same going into pump but negative reading. If good check vav hose going to fuel pump is not cracked and tight. If these are good check fuel hose coming from tank has good flow, if very little flow take gas cap off and see if flow changes, if still slow clean nipple at tank if gas tank is located under the hood. Look for grass or stuff clogging nipple. If no fuel filter is inline carb will get clogged at inlet and at main jet.
davis2
Sounds like fuel can trash blocking the tank nipple or the inner rubber of the fuel cap is coming apart and is now got bits of it in the tank. If you have to run it with the choke on, there is a fuel starvation issue.
This happened to my old Sabre
Yes this is a big deal with those that have the old style fuel cans. Most of the spouts are uncovered letting all kinds of debris into the can. Just gets passed to the carb jets and the like. Then you get a no-start condition.
You can buy a new style spout for your old can. Only a couple bucks. I "think" it keeps the fuel fresher. Not to mention water/humidity incursion.
