You will have to give us a lot more information before we can provide you any help. We hate making guesses when we don’t have good information. Please provide us with the following.
1. We need all engine numbers, model, type and code.
2. How long has this been going on?
3. Has the unit been sitting for an extended period of time?
4. Has anyone tried to fix the problem. If so what did they do?
5. When was the last time the engine was serviced?
6. What are your mechanical skills?
7. Have you removed the fuel line at the tank to check fuel flow there?
8. Have you check for debris in the tank, blocking fuel flow?
When we get this info, we will have a better idea how to proceed. You need to help us before we can help you.
